![](/img/219297/41815/image.png)
![](/img/219296/38823/image (1).png)
![](/img/219299/74788/image (2).png)
![](/img/219298/31337/image (3).png)
geposted Tue 17 Jan 17 @ 6:54 am
When I used V7 I set my screen resolution to 1366x768 or 1440x900 and chose close to the same resolution when selecting the default skin. That's pretty low in todays standards, but never gave me problems
geposted Tue 17 Jan 17 @ 7:30 am
The problem is that 3840x2160 is a huge resolution (pixel count) for a 15.6" screen. That's a 4K screen!
I have two 15.6" laptops and they're nowhere near that pixel density. Not even HD (1920x1080).
As Klaus said, 1366x768 is a more sensible resolution for a 15.6" screen. Of course if you cram more pixels into the same screen size, each one will be smaller. Plus VDJ skins (for VDJ 8) are designed for 1920x1080. Most VDJ 7 skins are for smaller/lower resolutions.
Another problem is that running VDJ 7 with a skin that doesn't match the screen resolution stresses VDJ and your computer.
[later] Are you 100% SURE that 3840x2160 is the correct resolution of your screen? I just downloaded the spec from Toshiba and it says the screen is 1920x1080.
If were you, I'd set it to 1920x1080, get rid of the 250% magnification (shouldn't be necessary when the screen is at the right setting) and try VDJ with a 1920x1080 skin.
geposted Tue 17 Jan 17 @ 7:05 pm
My gig laptop is 13.3" and has a 4k screen. It's ridiculous.
I have downscaled to 1920x1080 to match the V8 default skins and it's so much better.
Windows STILL has issues with scaling even in 10. It's a legacy issue for both programs and Microsoft and not nearly solved.
geposted Tue 17 Jan 17 @ 7:11 pm
I have a 15" 4k laptop, and I wouldn't want to go back ever again.
Text looks so much nicer, as do pictures.
There's a few programs that don't handle it perfectly yet, but most of it are fine in my experience.
VDJ 7 was indeed from before high-resolution screens, but VDJ 8 handles it perfectly.
geposted Tue 17 Jan 17 @ 8:01 pm
Can you post a screen grab (or a link to download the image) so we can have a look?
I think that running a standard VDJ 8 skin (1920x1080) on a 15" laptop screen has several issues, which have been raised on the forum before. Certain elements become too small, for example the browser tabs and the text inside them.
geposted Tue 17 Jan 17 @ 8:18 pm
If I maximize the skin, the elements are exactly the same physical size as showing the same skin on a 15 inch 1080p or even a 720p monitor. (a button of 1cm is still 1cm) so not sure what you want a screen shot from exactly.
geposted Tue 17 Jan 17 @ 9:49 pm
