The possibility to drag and drop (move) music files from the Sidelist to the Playlist and vice versa.
Perhaps switchable as an option. Thanks
geposted Tue 31 Jan 17 @ 11:02 pm
Grab the track (or multiple tracks selected with SHIFT or CTRL combination) you wish to move to another Sideview List.
Move it above the button you see at the bottom that offers the List you wish to move that to.
Hold it there for a couple of seconds.
The other List will appear in sideview.
Drop (release mouse) inside that List.
PS. This procedure copies the track from one List to another. Its not "moving" it
Alternatively, you can use the action switch_sidelist_playlist to "swap" the content of Sidelist and Automix
geposted Tue 31 Jan 17 @ 11:10 pm
Thanks for the reply! But I need the following solution:
I don´t want to copy the files but move them.
Here's an example:
With this result:
Here's an example:
With this result:
geposted Fri 03 Feb 17 @ 12:11 pm
If you want to move them rather than copy, then hold down SHIFT while dragging and dropping.
geposted Fri 03 Feb 17 @ 12:14 pm
That works in Windows but not in VDJ. For the hundredth time please just give us a browser option to either MOVE or COPY between sidelist and automix.
geposted Fri 03 Feb 17 @ 12:34 pm
It does work in VDJ.
At least between songlist and folders view.
But I'm not sure if it'll work between automix and sidelist. I guess not.
geposted Fri 03 Feb 17 @ 12:55 pm
geposted Fri 03 Feb 17 @ 5:14 pm
I'll start the topic again
+1
Here a similar question
http://virtualdj.com/forums/224352/Wishes_and_new_features/Ability_to_drag_a_song_OFF_the_turntable__down_into_the_Sidelist___Automix_window_below.html
+1
geposted Wed 05 Sep 18 @ 7:26 am
