Greetings, I hope that they guide me and excuse my English, I use a ddj-sx, and remapped long ago to use the filter with other functions when pressing fx assing 1 and 2 of each channel, with the fx1 active filter works, and with the fx 2 works the key smooth, and works seamlessly with skins of 2 or 4 independent deck in each channel, I would like to add or activate 2 more effects to the functions SHIFT FX1 and FX2 that could be noise and echo. In this way emulate the pioneer colorfx, but it is not possible to map the entire set.
I hope the echo can be mapped to the filter in this way, in the middle the effect is turned off, spinning to the right activates the effect to a beat and raises the level, and turning to the left activates the 3/4 beat effect And raise the level.
In this video I show how the first thing I already mapped works
geposted Fri 10 Feb 17 @ 4:50 pm
