Topic: How can I set PAUSE in a script ?
How can I SET_PAUSE or SET_PLAY_PAUSE at a certain area with a script assign to a button (keyboard) ?
Just like a SET_CUE 3 assign to a button.
In the POI editor you can set the command PLAY_PAUSE in the area of a song and when it reaches it, it will PAUSE the song but I like to do this in just a push of a button (just like SET_CUE #).
TIA
geposted Mon 13 Feb 17 @ 7:03 pm
If you want to create an action POI with a custom button (in other words via VDJ Script) then that's not possible at the moment.
The ONLY way to create an action POI is via the POI editor.
geposted Mon 13 Feb 17 @ 11:50 pm
thanks Phantom. I can now rest from searching n trying.
geposted Tue 14 Feb 17 @ 3:04 am
