The volume on a couple 3rd party plugin effects are too low. What's the trick to increase the effects volume?
geposted Sun 19 Mar 17 @ 1:20 am
click on List & Advice / Sampler and click on the config ICON on the sample you want to edit (under edit column)
geposted Sun 19 Mar 17 @ 2:11 am
Thanks for reading my question, though I'm sorry you lost me there. Are we talking about a way to increase a plugin's volume or a sample's volume? I found some dll's for vst sequencer plugins that I would like their volume to be louder about 5% or 10%. I'm not running an early access VDJ update. Not sure where "List & Advice" is in VDJ 8.2 b3573 and if it will make the plugin louder.
geposted Sun 19 Mar 17 @ 2:33 am
