Hi
First post after a few years of problem free djing but this one is driving me insane!!
On 8.2 with MC6000 mk2.
I seem to have lost the mic settings. Setting reset didn't work either.
At the moment I can switch on and off on the Virtual mixer but not the buttons. Well I can switch channel 2 off with the button with the mic plugged into channel one and I have lost the use of the echo..
Last week I had mic but it was on full gain and could only be controlled on the computer with no gain or switches working on the decks...
I am not the most computer savvy so if anyone CAN help please speak slowly..!!
Thanks, Peet
Thanks, Peet
geposted Mon 20 Mar 17 @ 3:48 pm
The mics are hardware controlled and nothing to do with Virtual DJ. Sounds like your controller has a fault.
geposted Mon 20 Mar 17 @ 3:53 pm
If you dont want to record Microphone along with your mixing, then you shouldn't follow the REC OUT/MIC Audio setup either.. http://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/advanced.html
geposted Mon 20 Mar 17 @ 3:59 pm
Thanks for replies.
They do connect as if I change a setting it affects the decks though not consistantly which is what's driving me mad!
I'll switch the mic/rec switch to usb then see if it helps!
geposted Mon 20 Mar 17 @ 4:05 pm
does anyone know how to set up mic shortcut key for vdi 8
geposted Tue 16 May 17 @ 11:13 am
