I having an issue getting my full iTunes library to show in virtual dj 8. I have already check the XXML box and all. Ever time I open VDJ 8 I get this error "The database on drive root: is corrupted, Do you want to fix?" but I can't seem to figure out how to open up the browser and clean/fix the database "root". Can anyone assist?
geposted Fri 24 Mar 17 @ 6:56 am
I'm having this issue as well. Did you ever get a fix for it?
geposted Mon 29 May 17 @ 5:04 pm
At one point iTunes changed their database file. I have no idea where it is on your Mac as I run Windows but the new DB name should be "iTunes Library.xml".
Open VDJ and then Settings, search for "itunes" and see what file you have set for your "iTunesDatabaseFile". Make sure the pat ends with "iTunes Library.xml".
Try some searches for that around here as that initial problem started some time ago. It is an older topic.
geposted Mon 29 May 17 @ 6:57 pm
