Topic: Master Video effect bug?
VDJ RonPRO InfinityMember since 2010
If I'm using automix with a playlist whilst using say slideshow then when the song changes the second effect such as text is switched off???
Also another effect is selected, and last night started!
I got a shock seeing myself facing my laptop on the projector screen!!!!!!!
At first I thought Don's plugin was the cause, so I deleted his software. However now the camera is selected. Hm I've disabled that in Win 10 settings.
I'm running the latest vdj version ..ending in 63 I think as recommended by djdad to resolve Deezer issues. However this problem has been there for a while.
geposted Sat 01 Apr 17 @ 3:18 pm
I'm testing it now and its perfect..without my XDJ R1 and Traktor F1 connected.
Hm I suppose it could be something to do with the F1.
While I was using my Akai mini I had no such problem.
Its getting a bit much when I appear "face on" on my LARGE projector screen LOL.
I'm betting that the return of the Akai gets rid of the problem!!!
Hm I've changed the F1 mapping..I think it's something I've modified.
Sorry for thinking this through on the forum.
I keep suspecting Traktor stuff messes vdj up.
geposted Sat 01 Apr 17 @ 3:38 pm
Hm ..Loop Roll managed to switch itself on last night, that caused me some confusion.
It's odd, in the past effects have been selected in the master slot, and others turned off, but never switched on.
To achieve stability I disconnected from the Internet.
geposted Sat 01 Apr 17 @ 4:24 pm
When I put "video_fx_select" on a knob when turned it moves through the available effects in the slot..but it also switches off the already active effects?????
So say I'm running slideshow and I want to put text over the top so I rotate the knob..but it then turns off the slideshow????
"video_fx" would turn an effect in the slot on/off. Could that explain the on/off thing with which I'm having trouble?
I suspect a bug.
geposted Sun 02 Apr 17 @ 2:17 am
That's the difference between fx_select abd fx_select_multi
Multi allows multiple effects to be active at the same time
geposted Sun 02 Apr 17 @ 4:56 am
I'm confused for the moment.
I thought I saw a "video_fx_select_multi" option yesterday but its not there now.
I have updated the software this morning.
geposted Sun 02 Apr 17 @ 1:09 pm
There isn't, but as you can see in the help from effect_select_multi, you can achieve the same with that:
effect_select_multi "video"
geposted Sun 02 Apr 17 @ 1:27 pm
I did a simple copy and paste to filter 4 (knob) on the F1 but it did not enable the selection of the video effect.
The other script works but switches all the video effects off.
I've got no time now..it will have to wait.
geposted Sun 02 Apr 17 @ 1:48 pm
Maybe below..I'll try it. Something is wrong.
effect_select_multi "video_fx"
The manipulation of video effects is very important to a video dj. It needs to be fully controlled via knobs, buttons, and faders. Using a laptop touchpad is inadequate. An interesting example is given by the text effect which can be made larger or smaller, and moved up or down smoothly using knobs to control the effect parameters. I find video effect control is more important to me than audio effect control which I rarely use. If I want to modify the music I can add and subtract elements such as a kick drum or whatever. Audio subtraction is of course done using the channel eq's.
geposted Mon 03 Apr 17 @ 1:32 pm
try
deck master effect_select_multi "video"
geposted Mon 03 Apr 17 @ 1:50 pm
It works.
Thank you, both of you, you guys are fabulous!
geposted Mon 03 Apr 17 @ 2:17 pm
