Topic: XDJ-1000 mk2
Hi
I just bought 2 XDJ-1000 mk2 thinking that there would be no issues with VDJ 8. Think again :-/
When can I expect native support for this unit?
Has anyone made a costum mapping yet ??
geposted Fri 21 Apr 17 @ 3:02 pm
Am I the only one who has this problem??
geposted Tue 25 Apr 17 @ 5:13 pm
I would imagine most people spending that kind of money check they are compatible and supported first.
They look visually very similar to the mk1 units, have you tried that mapping. If you have some knowledge you may be able to just tweak that. You may need to create a definition file though. Unless you have that skill then you will have to either wait for it to be mapped or exchange for something that is supported.
geposted Tue 25 Apr 17 @ 5:18 pm
Hello,
I have the same problems. Its impossible to copy mk1 mapping for mk2 device.
geposted Sat 10 Jun 17 @ 4:32 pm
Hi, does anyone has this mapper XDJ-1000 MK2 mind sharing please.
geposted Thu 29 Jun 17 @ 1:18 pm
There's no mapper for XDJ-1000MK2 yet.
geposted Thu 29 Jun 17 @ 3:45 pm
I did manage to map a few basic buttons to work such as cue, play, nudge, pitch slider, master tempo, hot cues & loops, but can't & unable to command the jogwheel.
Any ideas how to map the jogwheel? Please help.
geposted Tue 04 Jul 17 @ 10:50 am
Very basic Jogwheel controll should be possible by either using "joghweel" or "touchwheel" action.
Depending on the jog type. I think you should try "touchwheel" first.
Maybe have a look how similar controllers are mapped.
geposted Tue 04 Jul 17 @ 11:22 am
Official support for XDJ-1000MK2 will come very soon. So just be a little patient! :)
geposted Tue 04 Jul 17 @ 11:36 am
Thank you, noted.
geposted Tue 04 Jul 17 @ 12:21 pm
Thank you
geposted Tue 04 Jul 17 @ 12:22 pm
