Did the crayon box disappear? Or am I just missing something?
Right clicking gives me the ability to edit the hex code, but nothing else.
Mac 3738
Mac 3738
geposted Fri 19 May 17 @ 3:25 am
Perform a LEFT (normal) click and not a right-click.
Also you can choose which color picker will show up by changing the "colorPicker" setting inside VirtualDj configuration -> Options
geposted Fri 19 May 17 @ 7:48 am
Will check now. Thanks.
geposted Fri 19 May 17 @ 7:50 am
Got it. Thanks!
geposted Fri 19 May 17 @ 7:54 am
