You all must be wondering,right??So as we know that VIRTUAL DJ7's skin is awsome.But when you have VIRTUAL DJ8 which is new version you just can't download that skin online because you won't find it....
So,here's the solution:
Just install VIRTUAL DJ8 and then download VIRTUAL DJ7.
After you will install VIRTUAL DJ7 close it and open VIRTUAL DJ8 .
You'll see dialog box saying to import new data.Just click ok or yes.
Then goto settings and you'll find VIRTUAL DJ7's skin.....
That's all you need to do.
geposted Thu 15 Jun 17 @ 6:03 am
But it doesn't come close to matching all the functionality of v8.2 - so you are missing out on a whole lot of stuff when doing this.
And some stuff on the v7 skin won't work the same way anyway - like the pane buttons in the bottom - because VDJ 8.2 works in another way now
And the old skin is not made for the v8 skin engine, which is much more advanced than the v7 skin engine
My suggestion:
Don't go back in time and limit yourself like that
Find a skin you like that is made for v 8.2 (even v8 skins are too old, because they won't include stuff like Pad Pages)
geposted Thu 15 Jun 17 @ 6:53 am
