Did anybody used one of this ,can you tell me what do you think how do they sound's, on spec.. to me they sound good I have heard them once but just did not know did they used subs with it they sounded well bassy, fat. to me... I 'm confused a bit now they sounded very powerful and loud that night or I just was to drunk hahaha
I would like to go with that one because they are compact enough power in small package ..
geposted Fri 16 Jun 17 @ 10:23 pm
A very interesting topic/question.
They will do big jobs for you all by themselves..their legends!
Sort of like a Shure SM58 only higher up the food chain, so to speak.
I don't know what the "E" is about?
Add suitable bass bins and you can almost do any job.
They might be a little old fashioned now?..but they kick ass!
You need quality speakers more than any other piece of kit..that's the place to spend your money.
Check for the availability of spares..a good set will last years. Peavey who make the similar Impulse1012, which I use, no longer adequately support their speakers in the UK.
geposted Fri 16 Jun 17 @ 11:28 pm
I had 4 of these back in the 2000's and they are very compact and sound great. Unless you can buy them at a great deal and don't mind lugging a amp around I would suggest a powered pair even the EV ELX 12p In my opinion sounds as good and a lot cheaper and easier.
Good Luck!
Dave
Good Luck!
Dave
geposted Sat 17 Jun 17 @ 4:02 pm
Thanks guy's for your replay, I still like my amp I don't like powered speakers.... I like heavy amps
geposted Sat 17 Jun 17 @ 8:43 pm
