Just getting to grips with hot cues after ditching sorento. The default behaviour when pressing on a hot cue, after it's been set, is to cue and start playing. (from a paused state) Is there a way to make it move to the hot cue position without playing? I've tried holding shift or control or alt. Right click deletes the cue so I cannot use that.
I've looked in options for cue and there is a setting named cueMode with a choice "cue-hold". This sounds like it would do it but has no effect on the hot cue playing on selection. Perhaps that is a setting for the cue button and not hot cues?
Before I go down the script route is there a way of doing this which I've not found?
geposted Mon 26 Jun 17 @ 4:18 pm
          If you press on Paus/Stop you will jump through all your cues.
    geposted Wed 19 Jul 17 @ 7:43 am
          You need the hotCuemode setting set to "Stutter"
    geposted Wed 19 Jul 17 @ 9:07 pm
