Hi all,
Noticed something new today. Every time I load a song onto my side list in VDJ8 it's automatically reanalyzing every track I put in (even though they've already been analyzed). Never seen it do this before, but I also recently downloaded the update to v3780. Not sure what the purpose of this is or why it's doing it. It's tolerable but slowing me down a bit - is there any way I can disable this feature?
Thanks!
Thanks!
geposted Wed 05 Jul 17 @ 5:05 pm
http://www.virtualdj.com/forums/218621/VirtualDJ_8_2_Technical_Support/Scan_when_adding_a_track_to_an_Automix_playlist.html
Tracks not analyzed with the new algorithm will be rescanned.
What do you mean by slowing you down btw? You don't have to wait for it, it happens in the background and you can load any track on the deck instantly.
geposted Wed 05 Jul 17 @ 5:11 pm
It's slowing me down when I'm loading entire playlists and it's changing some of my BPMs (which is the bigger issue - it hasn't happened too many times, but it's only re-analyzed about 100 of thousands of songs). I just got the option to update a couple of days ago, so none of my music has been analyzed by the new algorithm yet. As long as this is normal/to be expected, it's not a big deal, but I'll just have to be careful.
Apologies for the double thread - didn't see the other before I posted. We can close up this one, no worries.
geposted Wed 05 Jul 17 @ 8:40 pm
Closed per OP request by AMAHM
geposted Wed 05 Jul 17 @ 9:00 pm
