What's up DJs.
I have a Harmon Kardon Bluetooth speaker that I've paired with my MacBook pro and using my VDJ and Numark controller but the sound has a delay about 2 seconds behind and I'm trying to see if that's a software setup/ configuration issue or if VDJ just doesn't work. When I play through You tube or other softwares, the sound is on point.
Anyone know how to correct this delay issue? If I connect the music through hard-wire, it's just fine.
Thanks in advance DJs.
geposted Fri 07 Jul 17 @ 1:53 pm
Alfred Muoki wrote :
What's up DJs.
Are you sure it's on point with other sw?
Because bluetooth is expected to have delay.
Normally that doesn't matter much - but when you mix it does matter
That being said 2 sec sounds like a long delay
Anyway:
I wouldn't use bluetooth for DJing.
Not on speakers and not on headphones
geposted Fri 07 Jul 17 @ 2:02 pm
Yes, it's perfect with youtube.
I'm just trying to do it for my home ease instead of being tied to a spot, I like to go to my backyard after hours and enjoy some video mixing and if I were able to get this Bluetooth thing worked out, I'd be golden.
But I hear you, if the technology isn't there yet, I get it, I was wondering if there's some adjustments I could tweak to make it work, yeah, 2 seconds is an eternity in mixing.
geposted Fri 07 Jul 17 @ 2:06 pm
Maybe look more into how you send to it
I mean: You don't connect bluetooth to youtube. You connect bluetooth to something that streams youtube and plays it
It's a bit of the same with VDJ. That just talks to a sound card driver. So there has got to be something in between that you can look into
geposted Fri 07 Jul 17 @ 2:11 pm
This is normal for bluetooth, the latency is always too high for mixing.
geposted Fri 07 Jul 17 @ 2:21 pm
Thanks Klausmogensen, I play you tube through my MacBook's wifi and Bluetooth to the speaker and projector.
Thanks Serine, that's what I was hoping not to hear, but suspected.
you're all awesome.
you're all awesome.
geposted Fri 07 Jul 17 @ 3:16 pm
Hi
I run two of the Turbosound IP2000 for my mains. I experimented a LOT with the bluetooth capability. There really is no way around the delay, certainly not the fault with VDJ. Man, it really messes up karaoke songs-lol.
geposted Fri 07 Jul 17 @ 8:51 pm
