Forum: VirtualDJ 8.1 Technical Support
Topic: Build 3807 failed
When attempting to update to 3807 I get the following error: "VirtualDJ automatic update failed, do you want to try again?" I have tried again about 4 times and still get the same error.
geposted Sat 15 Jul 17 @ 2:07 pm
geposted Sat 15 Jul 17 @ 2:11 pm
Before using the installer from the link above, you can also try to delete the ready.*.* file you find in /Documents/VirtualDJ/Cache folder and open VirtualDJ again.
geposted Sun 16 Jul 17 @ 12:43 am
