while moving the jog as you were scratching or searching for a part of a track. After a while my 400's start doing this.
https://youtu.be/VB25mW5T43U
were working normally but this is the second time at a gig this has happened making the decks near useless.
Thank you
Thank you
geposted Sun 16 Jul 17 @ 9:22 am
DAM, Finally I have the same exact problem.
Can anyone solve this ??
https://www.youtube.com/watch?v=VB25mW5T43U
HELP US!
My Setup:
- ASUS FZ50VX Windows 10 64bits
- 2 x Pioneer CDJ 400 in HID Mode (Direct Gold USB cables)
- Pioneer DJM 800 (Connected to PC with M-Audio Midisport Uno)
- Novation launchpad mini
P.S. I use it as a Videoclip DJ
HELP US!
My Setup:
geposted Tue 23 Jan 18 @ 12:28 pm
I am running on Windows7 and have the same Problem when I start VDJ the first time after boot with the DDJ-RZ and previously with the DDJ-RB too.
I usually start Controller and Laptop at the same time. When I load the very first song on Deck 1 and touch the jogs something similar happens. But only for a brief moment.
The Track skips so some random position forward or backward. Same goes with Deck 2, 3 and 4. But once it happened one time, its fine after and doesent happen again. I usually trigger the "bug" after startup by loading all 4 decks and touching the jogs, before I go live so it doesent happen during set.
I ve talked with Norman Beats (dj-in-norway) about this and he thinks also it might be a bug. Not sure if it is the same issue you guys have with your CDJ's but somehow I feel it could be related.
geposted Tue 23 Jan 18 @ 4:39 pm
