Hi all,
I bought my Numark Party Mix controller packaged with Virtual DJ LE back in late April/early May of this year. Initially I was never able to sort files by artist in it (this is how I sort my files in other DJ softwares) and then POOF, one day I was able to sort by artists.
Now for some reason I'm not able to do it again and I don't know why. After digging around a bit I learned there's a button that should be in the lower left corner of the display, above the font resizing buttons. that's not there anymore. In addition I really can't find a setting in Options that would toggle it back on...
Here's a screencap of what I'm looking at now; I've (poorly) circled the places where the button above the font size buttons should be, as well as noting my software is in fact VDJ LE:
http://imgur.com/BSEEUuz
Any help on this would be super awesome! I'm using VDJ on Windows 10 by the way...
geposted Wed 02 Aug 17 @ 2:36 am
Nevermind, got it figured out. Turns out I don't have the correct license to have library management access!
geposted Wed 02 Aug 17 @ 4:34 am
Yes you should definitely upgrade to at least a controller license
For the Party Mix that's only $49:
http://virtualdj.com/buy/index.html
That will give you almost everything, but only for the Party Mix controller
Comparison chart:
http://virtualdj.com/products/virtualdj/comparison.html
Comparison chart:
geposted Wed 02 Aug 17 @ 6:23 am
