same with the disply the faders are also opposite
everything looks ok with the sound config, what am i missing here ?
VDJ 7.4.7
MAC 10.9.5
config: none or line ins
Headphones (Master: Chan 1&2 / Headphones: Chan 3&4)
4-out card -> DN-MC6000
VDJ 7.4.7
MAC 10.9.5
geposted Tue 08 Aug 17 @ 6:08 pm
Front of unit
Switches A thru B for the 4 channels
Make sure you don't have B on ch L and A on channel R
geposted Tue 08 Aug 17 @ 11:27 pm
Check which interface or skin you are using. I have the MC6000 also and was using it on VD7. I changed the skin and channel 1 was playing on the 2nd channel on the left instead of what i was used to on the far left. The same with the channel 2 and 4, they were flipped on the right side.
I change to a different skin for the MC6000 and it fixed the problem.
geposted Thu 17 Aug 17 @ 3:44 am
Cant recall if the original ver7 mapping was based on 1-2-3-4 or 3-1-2-4 mixer order, but thats what u need to do in case you need a 4 deck skin,.. change to a skin that supports this mixer order.
If its 3-1-2-4 what you re looking for, here is one in that order. http://www.virtualdj.com/addons/15676/VirtualDJ_7_(4_Decks)_AIO.html
and some more ... http://www.virtualdj.com/addons/skins.html?category=all&order=default&resolution=all&search=3-1-2-4 (some of them support both of them)
geposted Thu 17 Aug 17 @ 3:38 pm
