Hi, Can we have a speed override control in the Tag Editor. There are a few songs from the 60's that I listen to at faster speeds than the original. If I could "set" that speed in the tag editor then I wouldn't need to control the speed. The default speed could always be 0. And a check box for keeping the same timbre otherwise a speeded up recording will sound like Mickey Mouse!!! Thanks.
geposted Sat 12 Aug 17 @ 7:45 pm
It won't help you to set the bpm in the tag editor. That's just info, so that would just list your track with the wrong BPM
But you can create an action POI that set's the pitch to a pct of what it really is. Like 110% for 10% faster than the original
To get the track to stay in the same key you just enable key lock - my key lock is generally always on
I made a quick n' dirty video that first shows pitch change without and then with key lock
It then shows how to create an action POI that changes the pitch 10% up, and starts the track twice to show how it works
It then show a reload and play of the track to show that the info gets saved for the next time you load and play the track
geposted Sat 12 Aug 17 @ 7:56 pm
