I currently use a home PC and a Laptop with VDJ. All of my music is on an external hard drive. When I edit songs on the home pc (BPM, Cue points, etc) then hook the hard drive to my laptop, none of the changes are saved in VDJ. I have to re-dop the edits. Is there a way to make them save so when I edit a song file on one computer, it's still edited on another computer?
Thanks!
Brad
Thanks!
Brad
geposted Fri 18 Aug 17 @ 1:27 am
If your music is really just stored on your external all edits should also be available on your other system.
All edits, cues, tags etc... are stored in the database.xml which is located on M:\VirtualDJ\database.xml
(Assuming your external has drive letter M)
geposted Fri 18 Aug 17 @ 10:52 am
