I am using vdj 8.2 and on hooking up a projector or even the tv to the laptop, of course the projected image is identical to that on the laptop. When playing a video clip, what do i do to project just the video clip ? I just can't seem to find the answer anywhere.....
geposted Mon 04 Sep 17 @ 10:09 pm
Are you using a Mac or PC??
On either OS you should be able to find an "Extend my desktop" button somewhere.
Just try google.
Just try google.
geposted Mon 04 Sep 17 @ 11:40 pm
that manual would also help with what you're trying to do
https://www.virtualdj.com/manuals/virtualdj8/interface/mixer/videomixer.html#videoout
geposted Mon 04 Sep 17 @ 11:43 pm
the winchester wrote :
... the projected image is identical to that on the laptop.......
Probably you have set it to incorrect mode.
Something that is not mentioned in the manual is that you need to have the Projector (TV, secondary monitor) in "Extended" mode and not in "Clone" http://www.virtualdj.com/wiki/Video%20output%20to%20an%20external%20monitor.html
geposted Tue 05 Sep 17 @ 1:57 am
Many thanks guys.....was simple really wasn't it.
geposted Sun 25 Mar 18 @ 9:07 am
