Is there an alternative method to backup FX settings? After the new BETA install my carefully tuned echo FX settings were trashed and the effect was reset back to stock. I think this has happened in the past after previous updates. My other FX seem to have retained their settings but the echo was reset after the BETA 3889 update. Any tips on how to backup all FX settings are much appreciated.
geposted Thu 07 Sep 17 @ 7:06 pm
Just go on plugins folder and backup the native_*.ini files
geposted Thu 07 Sep 17 @ 7:54 pm
Thanks! Is it usual for VDJ to erase those settings on upgrade or just a bug that might be fixed?
geposted Sun 10 Sep 17 @ 11:53 pm
