Topic: ask the dj help!
Hi,
I a looking at using the ask.the.dj section of the program. So I go to setup and all is good only, how do I change my DJ name, as there it looks like this ( starlight__party__dj ) which is great if it did'nt have double under scores. I am sure I used to be able to us my twitter name which is starlightdj1 . is there a way to change your DJ name as this will prove a nightmare both in saying it over the mic and also by placing card on the tables..
thanks
Gary
geposted Fri 15 Sep 17 @ 2:16 pm
I only use Twitter and it works fine.
Just make sure you have the setting askTheDJTwitterHashtag as your name (without the @) and it will work.
You can't have Twitter and web interface at the same time so if you have anything in that setting Twitter will take precidence.
geposted Fri 15 Sep 17 @ 2:22 pm
My preference would be to use twitter. I also had cards made for weddings that i place on most of the tables with my request info so that i don't have to announce it every so often.
geposted Mon 18 Sep 17 @ 11:52 am
