i prefer to use DJ 7. Is it poseble too pre-listening during VIRTUAL DJ RADIO; I have the 8.2b3870 version
geposted Sat 23 Sep 17 @ 5:07 pm
I found it my self.
Tthis is how i do it
what you need is a headphone with a usb connector or e device with a usb connector on one side and a two times (micro and headphone ) 3.5 jeks on the other side.
Then you swap in your adio settings from on soundcard to two soundcards
Your Master has to be on chanel 1&2
and your headphone also on channel 1&2
put your ballans to the left
your box wil play tabel one
and your headphone wil play tabel two
geposted Sun 24 Sep 17 @ 11:29 pm
