I am about to get a used Hercules RMX it will not come with the usual supplied software disc I'm afraid which I think is called Virtual DJ LE, But I only need the Hercules RMX to do very basic stuff, am I correct in thinking my laptop having only 1.1 (Ghz) speed would be sufficient for DJLE software and if so can I get this software any-ware and does it need a licence for home use. Of course the fuller virsions of Virtual Dj would need at least a processor with 2 (Ghz) speed or more I know so my laptop is not good enough, am I on the write tracks folks or getting it wrong
geposted Mon 06 Nov 17 @ 10:26 am
You cannot buy a VirtualDJ LE license, but you can get a VirtualDJ 8 Plus license for that controller. (See https://www.virtualdj.com/buy/index.html for prices and more info)
The best way to know if your laptop is fast enough would be to try it.
You can download VirtualDJ 8, install it, and run it to try if you can load and play songs without problems.
https://www.virtualdj.com/download/index.html
geposted Mon 06 Nov 17 @ 10:47 am
I'm running VDJ8 on an atom processor with full HD video out and it's flawless.
geposted Mon 06 Nov 17 @ 12:15 pm
