everzthing has been rock solid for months. was just about to fo my weekly podcast. and
1: the music sounds awful. really muddy.
2: jogs work then stop. then the same with play button.
3: when not in vdj. and using aimp to play files they sound fine.
i think i need a re install of everything anyways. but just in case can someone point me to the ealier builds. the one before this was fine.
geposted Tue 28 Nov 17 @ 4:46 pm
bookmark this
https://www.virtualdj.com/download/build.html
geposted Tue 28 Nov 17 @ 6:01 pm
thanks!
geposted Tue 28 Nov 17 @ 6:43 pm
i upgraded to win 10. worked better. but had the old problem from previous pio controllers. where if on the right side, deck b. you use the filter. it wont shut off after releasing the button. grr
so i went after a build about 5 builds ago. and in properties. added it to work in windows 8.1 mode.
i think it was something with my video card drivers tbh.
but now its back up
but now its back up
geposted Wed 29 Nov 17 @ 2:27 am
