Hi Guys,
I know I've asked this before with regard to the RX and it pitch control accuracy in MIDI mode and was quite rightly told that it was a firmware limitation on the RX.
Well it seems now the new firmware available addresses this (https://www.pioneerdj.com/en/support/software/xdj-rx/#firmware-update) and I can confirm in RekordBox it has fixed the issue.
But when used in midi mode with VDJ it is still the same. Is this due to the midi map needing updating in VDJ? or do I need to change a setting somewhere?
Happy to be a tester if required.
Thanks in advance.
Mel
Thanks in advance.
Mel
geposted Wed 29 Nov 17 @ 11:00 am
We will check the resolution of the new firmware and we will respond back to you shortly.
Thank you!
Thank you!
geposted Wed 29 Nov 17 @ 4:11 pm
Thanks Guys!!
As I said happy to test anything if you do not have an RX handy.
geposted Fri 01 Dec 17 @ 4:51 pm
Hi - Is there any update on this?
geposted Tue 19 Dec 17 @ 3:34 pm
Still nothing on this?
geposted Thu 11 Jan 18 @ 11:26 am
