Using a 4 deck controller, as there are no 'Kill Eq Buttons' I'm wondering if there's a way to solve this by pressing shift button while using the according eq-knob (or moving it to middle position)? [Controller: Behringer MM-1]
e.g:
1. eq_kill_low = on when shift + EQ Low
2. eq_kill_low = off again as eq knob ist used whithout Shift
e.g:
geposted Fri 15 Dec 17 @ 12:08 am
Do you want an instant EQ kill? Otherwise there is an option for that. Just search for "eq" in the options. I don't now the exact description of the action but something like EqFullKill or so...
geposted Fri 15 Dec 17 @ 9:06 am
Yes I want instant EQ kill.
A way to toggle a certain eq condition by pressing a button + turning eq knob. Knob works regular again without shift beeing pressed.
(The option you mentioned is : equalizerMode | Default / Full Kill)
geposted Fri 15 Dec 17 @ 1:00 pm
