I've been tagging my music with an external MP3 tag editor using the subtitle field so when VDJ reads the tag it properly populate the remix field, this works without any issues with MP3s, but with FLAC the subtitle tag is ignored and the remix field remains empty.
If I open the FLAC in the VDJ's tag editor and write down the remix field and save it, this appears in the 'remixed by' field instead on the subtitles field when opened in the external tag editor. Then, I've tried to use the 'remixed by' field instead of the 'subtitle' one in the external tag editor but VDJ still ignores it.
I thought FLAC tags were be fully supported with all the same fields as mp3 as stated in here: https://www.virtualdj.com/homepage/wickedmix/blogs/5246/id3_Tag_Support_in_VDJ8
So, what's going on?
geposted Thu 21 Dec 17 @ 12:14 am
yeah that blog post needs updated things have change since i posted that ... see the title :-)
geposted Thu 21 Dec 17 @ 12:22 am
For flac, it is the VERSION field that is used to read/write the remix into.
geposted Thu 21 Dec 17 @ 6:24 am
