Hello! I've had Virtual DJ 8 for about 9 months now and I haven't experienced a problem like this to date. I have all my music on virtual DJ sorted in alphabetical order by artist, and this morning when I opened the app, all my music was perfectly organized until I plugged my controller in, and everything is out of order, just randomly placed. This is only for my iTunes Music and all my individual files are fine. Please help, its really hard to find songs now.
geposted Fri 22 Dec 17 @ 8:27 pm
That didn't just happen
https://virtualdj.com/forums/202865/VirtualDJ_8_0_Technical_Support/sort_order_in_iTunes_playlists_not_displaying_correctly_in_VDJ.html
https://virtualdj.com/forums/213248/VirtualDJ_8_2_Technical_Support/iTunes_12__playlist_sort_order_reversed.html
Long story short, your manual iTunes lists will show in VDJ correctly. Your Auto playlists will not. Very old problem, which has been blamed on iTunes. While I will not disagree that they changed something that caused this (as it once worked fine), other software vendors have fixed the bug. I am not sure why we just point at iTunes. They are obviously not going to change it back to the way it was.
geposted Fri 22 Dec 17 @ 11:36 pm
