Hello.
When I broadcast a live radio show, I usually record the show, then upload the show to our blog.
Is there anyway I can save the music as a .cue file so I can add a tracklist to Mixcloud when I upload the show?
I don't really want to type each line and cue each track.
I usually use MIXXX for this reason only, but I really want to use VDJ.
Help.
Thanks
Steve
Help.
Thanks
Steve
geposted Wed 27 Dec 17 @ 2:41 pm
There is an option to save a cue file in options under recording.
geposted Wed 27 Dec 17 @ 3:54 pm
Sorted. Easy when you know how!
Thank you
Thank you
geposted Tue 23 Jan 18 @ 8:05 pm
