I use virtual folders as part of my workflow to flag songs to be deleted, change genre, etc. As a song is played if I determine that some form of maintenance is required, I add it to the virtual folder used for the maintenance at hand. The function virtualfolder_add is working perfectly as long as the target is a root folder. When trying to use a hierarchy, this function either deletes the target folder or only keeps the last added song. Please try with the following folder structure.
Maintenance\Test
The script that is trigged from the key "," in my keyboard is this
virtualfolder_add "Maintenance/Test" & goto_last_folder & browsed_file_color "red"
If the virtual folder "Test" is a root folder, everything works fine. Is there a work around to have virtualfoder_add work with sub folders?
Thanks
Maintenance\Test
Thanks
geposted Sun 31 Dec 17 @ 1:01 am
You've used two different types of slash there. Are you on Mac or PC?
geposted Sun 31 Dec 17 @ 9:04 am
i am on mac. The first \ was a typo. The script is running with the forward slash. virtualfolder_add "Maintenance/Test" & goto_last_folder & browsed_file_color "red"
geposted Sun 31 Dec 17 @ 1:43 pm
