Hello People,
Sometimes, with a few Song Genres or at some Venues, I have Issues with the Highs and the Mids.
I've come to the conclusion that, different Song Genres and Club Equipment, need different EQ Settings. Some venues give you more Bass and others more Highs and Mids (Treble) etc etc. Depending on the Equipment ...
In the AddOns at the Effect Section, there are two different EQ Plugins:
One with 10 Bands -> http://www.virtualdj.com/plugins/index.html?addonid=16704
and one with 30 Bands -> https://www.virtualdj.com/plugins/index.html?category=effects&search=EQ+30
Will these EQ Effects solve this issue ?
and if Yes ... Which one is better for my case ? 10 Bands or 30 Bands ?
How do they Work ? do I Activate through the Effects in VDJ like the Flanger ?
I would appreciate it if somebody could help me out and give me some Info.
geposted Wed 03 Jan 18 @ 6:36 pm
EQ10 works properly, EQ 30 doesn't.
It will work and you can save presets for each venue (assuming you are using software mix and not an external mix configuration)
All you do is assign it as a master effect, and you can add an oninit in your controller mapping to enable it by default if you wish. Be aware the smallest movement makes a big difference .... I'm sure Scott said he was going to put in different EQ gain levels but that has never happened.
geposted Wed 03 Jan 18 @ 6:48 pm
Don't forget VST plugins. There are plenty of options there, from free EQs to things like this.
geposted Wed 03 Jan 18 @ 7:04 pm
Hello kradcliffe, Happy New Year
So, the EQ 10 (Effect) is what I need and works properly.
and it's Activated like a normal Effect, after activation, I choose the Preset that I need.
So all I have to do now, is to install it, try out the presets of the Plugin, to see if Sound-wise it gives me the Sound Quality that I need.
Thank you for your time my friend.
geposted Wed 03 Jan 18 @ 7:18 pm
Hello groovindj, Happy New Year
VST Plugins seems to be an interesting solution, when the specific sound file is the Issue.
Till now, I've been using Audacity (Freeware) and Izotope RX 4.
Can you recommend a Freeware or something similar that can fix a song when the Mids, Highs or Bass is not correct or sounds bad in a song.
Thank you for your time in advance.
geposted Wed 03 Jan 18 @ 7:28 pm
No I can't actually. When I find a song that needs help, I edit it with Adobe Audition and use mainly Waves plugins (and my ears) to correct things manually.
I just downloaded the 30 day trial of the fabfilter plugins so I will try those too.
geposted Wed 03 Jan 18 @ 7:39 pm
OK, Thanks groovindj
geposted Thu 04 Jan 18 @ 10:20 am
I've downloaded and installed the EQ 10 Effect.
I see that there aren't any Presets saved in this Plugin to try out.
I thought that there would be 10 Presets saved ...
So I probably have to make my own presets and save them.
Does anyone know if I can download or find some presets for this Effect ???
or maybe a Tutorial that shows the proper way to use it ?
geposted Thu 04 Jan 18 @ 10:27 am
It's not that complicated. The 10 refers to the frequency bands available.
All you do is enable it and get the best sound from it for your venue. Simple as that. No need for presets as they rarely match anyway.
geposted Thu 04 Jan 18 @ 10:46 am
here is the free VST EQ i prefer http://www.voxengo.com/product/marvelgeq/ it will allow you to create and save presets as well
make sure you are always running the EQ on your Master FX or you will need to have it on every deck FX to cover everything much easier to just have one instance on the master.
geposted Thu 04 Jan 18 @ 11:16 am
Thank you kradcliffe
geposted Fri 05 Jan 18 @ 6:38 pm
Thank you wickedmix
Sounds interesting and Helpful
I'll check it out
geposted Fri 05 Jan 18 @ 6:39 pm
