touching the jogwheel stops the play only.
i've gone into options and tried 'smartscratch on and off', 'vinyl mode on and off, and some others'
same controller works in vdj 7 and traktor pro
geposted Fri 12 Jan 18 @ 2:45 am
In the controller mapper, what is the definition for the jogwheel, and which build of 8.2 are you using?
geposted Sat 13 Jan 18 @ 3:50 am
So, touching the jogwheel, track stops (when playing), but when you release, it doesnt continue playing ?
Or the above works fine, but when you scratch (forward/backwards) with the jog, you dont get any sound ?
geposted Sat 13 Jan 18 @ 10:32 am
