Hey guys,
Im frustrated trying to import my SAVED controller map into VDJ 8.2 and ready to give up the app.
*I saved my Numark party mix control as an XML right in the app. Found the location.
* Sent the file to desktop.
* imported called "SIMPLE_MIDI_5604_56 - partymixtesting.xml" into my C drive/documents/virtualDJ/mappers
From here, I cannot pull up my mapped controller into VDJ8.2
Is 8.2 simply just rejecting the party mix controller as a control because it's low level????
geposted Fri 12 Jan 18 @ 3:00 am
This post is quite confusing. On the desktop, delete the mappers that you installed. Then follow these directions, to connect the Partymix on your desktop. VirtualDJ should recognize this controller. If you had custom mappers on the laptop, go to mappers, copy to thumb drive, and paste into mappers on the desktop. It should work. Make sure you are signed in on the desktop. You are listed as a home user, did you register the LE version with VirtualDJ?
geposted Sat 13 Jan 18 @ 3:42 am
