Topic: VDJ 8 brodcast in Second Life
i cant play on land in sl music
i have stream
when start play music for moment play in Second Life and vanished
geposted Sun 21 Jan 18 @ 7:30 pm
what is vanishing? .. need to be more specific..
geposted Sun 21 Jan 18 @ 9:32 pm
geemixPRO InfinityMember since 2006
Why not try to stream with VDJ and then put your shoutcast url and port into a web browser.
eg: http://yourstreamname.com:8080
Listen to your stream there via the play button from the shoutcast page that opens. See if your stream is still cutting off or not/
If so, it could be internet issues that are causing your stream to cut on/off by not streaming the data fast enough.
If that is the case, streaming at lower bitrate (kbps) may help. (Encoder quality setting)
Also, if you know another DJ on sl and can trust them with your stream details/password, allow them to test your stream to see if it cuts out for them also.
Or borrow their stream details to see if theirs cuts off for you?
Please also note, if you pay for a cheap stream service, you get what you pay for.
geposted Sun 21 Jan 18 @ 10:13 pm
