Is that normal that every time I hit the "padshift" button on the "custom"-padpage the Pad Editor opens up automatically?
I changed the mapping of the button to test if it is something like a hardware-related bug, but it only happens with "padshift" mapped on no matter which key on the keyboard or button on a controller.
Is that supposed to be like that or could that really be a bug instead?
If this is on purpose, why is that like that?
geposted Tue 23 Jan 18 @ 5:12 am
I normally create new named pad pages when I script new functionality, so I may not be the best to answer, but:
Could it be simply because it isn't mapped to anything?
Like if you click a regular pad without any script on it, it will open the editor, so that you can add script
geposted Tue 23 Jan 18 @ 9:25 am
I'm not sure why you would assign padshift to a custom pad button in the first place.
The only thing padshift does is execute the shift action of the pad, so you'd need to define a shift action for that pad as well then. (But then you could just use that action directly on the pad since it's your custom pad page anyway)
geposted Tue 23 Jan 18 @ 11:50 am
I took the "custom-pad-page" because it was already mapped to the Pioneer DJM-S9 and I wanted to try something on the quick way.
And then I discovered this "bug"... I also thought that it is something like "you first have to map something"-function.
But this should happen on other pages too if it is on purpose.
geposted Tue 23 Jan 18 @ 8:56 pm
I saw that coming :D
So no I did NOT map it to any PAD-Button.
I mapped padshift to a controllers button and on my keyboards key and in both times it opened the Pad Editor.
Therefore I somehow was confused because I did not know if this is on purpose or a bug.
As soon as I mapped something on PAD 3 of the "custom page" this (I think bug) was gone.
geposted Tue 23 Jan 18 @ 9:01 pm
It is not a bug, if you shift-click an empty pad button it will open the pad page editor.
geposted Tue 23 Jan 18 @ 9:06 pm
I think we are talking past each other somehow :D
I did ONLY press the button which had the padshift mapped on it...
I did NOT press any empty pad-button (or any other button) at the same time...
And as I mapped something on Pad 3, this was gone...
So I could press padshift from there on and I did not open the editor anymore... but only after I mapped pad 3.
geposted Thu 25 Jan 18 @ 3:45 am
The padshift action is like clicking a pad button, that's the function. It is supposed to be mapped on a controller buttons midi message sent when shift+pad x is pressed.
You are supposed to use it like the pad action (padshift 1, padshift 2, padshift 3, etc...)
Maybe you intended to map a shift button instead? In that case the action is simply 'shift'
geposted Thu 25 Jan 18 @ 8:37 am
