Topic: Mapping VDJ8 with Denon MC6000
After my HD was replaced on my Macbook Pro the vol sliders, the eq, and the pfl functions on screen (VDJ8) didn't function with the knobs on the mixer. How do I map those on screen functions to correspond to the same on my Denon MC6000? I've searched the forum with no luck, thx.
geposted Wed 31 Jan 18 @ 8:53 am
IDK, changing the mixer layout in options?
I went in to config and tried factory reset to no avail, my current mapping settings for eq_high set the trebble equalizer. (as well as the other eq settings).
Problem solved thanks to the VDJ support help (George). Apparently I needed to have the rear of the MC6000 set to PC mix and the output (in config) set to speaker + headphone.
My volume sliders and EQ knobs still aren't tracked to the proper decks. Any thoughts on this? Deck 1 and its EQ is controlled by nothing whereas Deck 2 and its EQ is for some reason controlled by slider 3.
In VirtualDJ Settings->OPTIONS tab, search for MixerOrder setting and see its value. Cant recall the default mixer order the MC6000 is mapped, so you may need to check both 3124 (default) and 1234 mixer orders
BTW, check which Mixing mode you are using and if your Audio setup is correct https://virtualdj.com/manuals/hardware/denon/mc6000/advancedsetup.html
I'm really new to this. I just upgraded to the mc-6000mk1 controller. I have watched tutorials on YouTube on how you can used each button on the controller. The problem I'm having is that the button functions of my controller don't match the functions on the tutorials videos. I think the functions shown on the videos are for traktor software.
How can I map my controller to have the buttons mapped to a traktor mapping on a VDj software
Did you mean DENON DJ MC-6000 MKII ?
Peek here for how to setup, and what each button on your controller will do in VDJ.
https://virtualdj.com/manuals/hardware/denon/mc6000mkii.html
And you are able to change the functioning of any of those buttons/knobs as you please, if you wish to change from the defaults.
