djsimonreed85 wrote :
I am running a 2014 MacBook Pro with high sierra.
DJSoulman wrote :
Mid 2010 MBP i7, High Sierra
PhantomDeejay wrote :
Perhaps it's a MAC only issue ? We will investigate further
We can confirm that this is a MAC only issue and that it will get fixed in the next build.
Thank you!
geposted Tue 20 Mar 18 @ 7:59 pm
After finding a fault/bug, I always wonder 'is it just me' until someone else confirms.
Even more relieved when the devs also find the fault.
Cheers
Les
Cheers
Les
geposted Tue 20 Mar 18 @ 8:53 pm
Great works guys.
Are there any plans to add Rekordbox support so we can view Rekordbox playlists in VDJ?
I’m planning on moving over to Rekordbox and leaving serato so that would be nice for myself.
geposted Wed 21 Mar 18 @ 9:13 am
I have a Problem with the Audio-Setup under Windows 7.
I have no Inputs and can not add it, so how can i set it up?
The second thing is that i have no "deckfxreturn" in the drap down menü from the Outputs. I can rename one, is that the right way?
geposted Thu 22 Mar 18 @ 8:49 am
link is not working
geposted Thu 22 Mar 18 @ 9:48 am
orensaban wrote :
link is not working
that is because it is now included in build 4189.
it is an early access build -> http://www.virtualdj.com/download/build.html
geposted Thu 22 Mar 18 @ 10:20 am
New Firmware 1.04 for DDJ-1000:
CHANGE HISTORY
Ver.
1.04 (27 March, 2018
Update
FIXED
Error when pressing SHIFT and using the jog wheel.
CHANGE HISTORY
Ver.
Update
FIXED
geposted Thu 22 Mar 18 @ 2:45 pm
The Problem with the soundsetup is solved, i have found it, just one click on the DDJ-1000 in the sound options.
geposted Thu 22 Mar 18 @ 2:55 pm
Does the DDJ-1000 button in AUDIO Setup sets deckfxsend to chans 9.10 ? There was a bug that was incorrectly setting the deckfxsend at the same channels as the deckfxreturn. If it is that way, manually set deckfxsend to 9,10
BTW, reason not having deckfxsend/deckfxreturn as options in the drop-list of inputs/outputs is that those are needed only for specific hardware and those are included in the pre-defined audio setup (the one that the controller button in AUDIO tab is offering)
geposted Thu 22 Mar 18 @ 3:00 pm
Operation Manual : https://virtualdj.com/manuals/hardware/pioneer/ddj1000.html
Not 100% finished, we need to add a few more things there, but you can start reading and get some useful information
geposted Thu 22 Mar 18 @ 3:03 pm
Yes the button sets deckfxsend to channel 9 & 10. Is there a way to get the mastersignal back to windows? I can see an Pioneer-DDJ100 Audio-In under Soundsetup on Windows, but i can't get a soundsignal from the controller.
geposted Thu 22 Mar 18 @ 3:56 pm
What for exactly ?
geposted Thu 22 Mar 18 @ 5:41 pm
So i can use it for my Lightsoftware to trigger the bpm.
geposted Thu 22 Mar 18 @ 6:51 pm
Hello everyone, I wanted to ask for advice, for the Pioneer DDJ1000 which skins can I use? I am a user with an infinity license
Thank you all
Thank you all
geposted Thu 22 Mar 18 @ 7:01 pm
You can use any skin.
geposted Thu 22 Mar 18 @ 7:03 pm
CHANGE HISTORY
Ver.
Update
FIXED
CHANGE HISTORY
Ver.
Update
FIXED
Thanks for the heads up, that's my night sorted.
Oh, and a manual to play with too. :-)
geposted Thu 22 Mar 18 @ 9:45 pm
CHANGE HISTORY
Ver.
Update
FIXED
CHANGE HISTORY
Ver.
Update
FIXED
The 27th of March? It's only the 22nd. Oh wait.....................where am I?????
geposted Thu 22 Mar 18 @ 10:42 pm
Seems like the space time continuum is broken again.
Apparently you are not only hours but meanwhile days behind us.
What's going on there over the pond?
geposted Thu 22 Mar 18 @ 11:44 pm
I'm not sure. I'm here..................but thought I was there, but keep hearing some guy say "What we gonna do right here is go back, way back, back into time". The next thing I know, I'm thinking about buying a pioneer DDJ-1000, but need to get the new firmware now, that will be released 5 days from now.
geposted Fri 23 Mar 18 @ 1:13 am
Well I've placed my order :)
geposted Fri 23 Mar 18 @ 1:48 am
