Using this filter script for a folder: filepath starts with "..." and remix contains "trans" or file name contains "trans" and color is "none", where file path is variable depending on location.
It works well, except for the color part on the end. Tracks still appear in the filter even after being colored. If I remove the "or file name contains "trans" portion", it works as desired.
Any advice?
Any advice?
geposted Mon 19 Mar 18 @ 6:11 am
Try put the color condition first.
geposted Mon 19 Mar 18 @ 7:17 am
Do you have both "and" and "or"?
In that case does it help to add parentheses to control the order of operations in the math?
For instance
(year>=2000 and title starts with 'A') or year<2000
Gives you very different results than
year>=2000 and (title starts with 'A' or year<2000)
For instance
Color condition first worked. Gotta love the forums! Thanks.
geposted Mon 19 Mar 18 @ 7:31 am
No worries, it's what we do.
I think the or makes any thing after it conditional on the or.
geposted Mon 19 Mar 18 @ 9:57 am
