Ever since about a few days ago (two or three as far as I can recall), VDJ8 has been crashing on startup. Strangely, it's not just a normal "crash": Everytime I double-click the shortcut or exe. file, it starts for a couple of seconds, crashes, boots up again, and crashes a final time. It always starts up and crashes automatically at least twice everytime I start it up, but I've seen it do it up to four times.
This didn't happen a few days ago, and nothing I can recall makes me think that it could have triggered this behavior on the program. Haven't changed any settings. Last time I used it I played and recorded a set on it, didn't start it up for a couple of days after that, and next time I decided to use VDJ, this was happening.
What the hell is happening? How do I fix it? An uninstall/reinstall hasn't worked.
geposted Sat 28 Apr 18 @ 12:24 pm
Please try to download the early access release from http://www.virtualdj.com/download/build.html
geposted Sat 28 Apr 18 @ 12:32 pm
I would check your plug ins
Backup your setting file, the return your settings to default or
I think if you rename your settings file on started a new one with the defaults will be generated
If there us a bad plug in toy may want to remove them one at a time
geposted Sun 29 Apr 18 @ 9:26 am
