Just wondering if with the home plus version you can use external speakers, or even multiple external speakers. This would be used privately and non-commercially of course. Just don't want to waste $100 buying it for it not to work. Cheers.
geposted Tue 01 May 18 @ 11:15 am
Yes it would be a pretty lousy deal if you couldnt.
geposted Tue 01 May 18 @ 11:23 am
If you're buying a Plus version then presumably you've got (or are getting) a controller?
In most cases the controller has an internal audio interface, and it's there that you connect the speakers & headphones.
geposted Tue 01 May 18 @ 4:44 pm
Yeah thought so, cheers.
geposted Wed 02 May 18 @ 5:28 am
