i have the history delay timer set to 10 seconds, after the song plays, it is supposed to mark it as played but there is no color marker showing up at all. does anyone know how to reset that setting and what is it called?
or is there a way to change the color of that marker in the xml database file?
geposted Wed 02 May 18 @ 2:25 am
This is what it supposed to be.
Dunno if there is an option to change the TEXT color when played.
Only the CHECK MARK states that it's been played.
geposted Wed 02 May 18 @ 4:27 am
The icon for music, video, karaoke, and their overlays can be different with a different skin. Only the icon changes. Sometimes you need to scroll in the file list to get changes to populate.
Below is a link to the manual that shows what it looks like with the default skin.
https://www.virtualdj.com/manuals/virtualdj8/interface/browser/fileicons.html
geposted Wed 02 May 18 @ 4:48 am
we're using the default skin in vdj8
geposted Mon 04 Jun 18 @ 10:09 pm
