Topic: sample record distortion
drjustPRO InfinityMember since 2006
having unknown issues with the sample record function,
Under the master section on default skin
before I hit the record button and play a track, the audio is clear
when I hit the record button ( using the default skin ) the audio play back from a deck turns into distortion, and the recorded audio file is also distorted, when I turn off the record button the track on the deck plays clear.
Checked usual things like audio level settings etc...all normal in the green
I recorded samples last nigh and it worked with no problems
need assistance to sort out the problem.
geposted Sat 12 May 18 @ 6:20 pm
I think ive resolved the problem via some help from the ticket support team
geposted Mon 14 May 18 @ 4:53 pm
.....and the solution was?
geposted Mon 14 May 18 @ 4:54 pm
" Can you try testing without the video engine enabled and see if the the quality is better? Also what is the CPU meter showing?"
geposted Mon 14 May 18 @ 11:33 pm
