Topic: Disable keyboard hot keys?
Is it possible to disable keyboard hot keys when using VDJ8? For example, sometimes I will realize I did not have my cursor in the "search"box and start typing. I will hit certain key and restart or stop a song. I would like to guard against that happening. Thank you in advance!
- David
geposted Sat 12 May 18 @ 9:55 pm
Yes, go to settings, controllers, keyboard, and under mapping choose ignore
geposted Sat 12 May 18 @ 10:00 pm
Perfect! Thank you =)
geposted Sun 13 May 18 @ 1:45 am
