Topic: Script School - Page: 17.75
have you any ideas??? thanks a lot
today my question is: if i use scripts like ‘mic_rec’ or ‘linein_rec’, in the deck there is the recorded…can i directly save a .vdj or .mp3 file (with script button that i don’t know) that is in my deck? or i can only put deck recorded in loop and use sampler_rec 1 (for example) to create a sample file .vdj? thanks[/quote]
TIP about complex actions in actions
( I don't know how site will accept this :\ )
Sometimes actions need to use result of actions and strings
they can use back quotes and quotes and apostrophes ( `xxx` 'xxx ' and "xx" )
when the result have to be display in a text or button or slider ....
the skin need to enclose it in quotes or apostrophes
text="" or format="" or action="" ...
this can be an issue
there is a standard workaround to this : remember xml entities : > < & " '
you can then write complex strings like that :
action="param_add `param_add "get_text ')' " 'param_add "get_automix_song artist +1"' " - (" ` `param_add 'get_automix_song title +1' "get_text ' Comming next : ' " ` & param_cast text"
hi at all, in my Pioneer DDj-RZX i have mapped 2 buttons like Rekordbox Sequencer..but i record from ‘master’ output…could i record from sampler output? for example i have mapped a button: sampler_rec ‘master’; i tried to write sampler_rec ‘sampler’ but doesn’t work :(; if i choose deck 3 output for sampler i tried to write button: deck 3 sampler_rec but doesn’t work :( can you help me? thanks!
deck 1 sampler_rec
works here, are you internal or external mixer?
locodog wrote :
deck 1 sampler_rec
thanks for answer, i have internal mixer mode, but deck 1 sampler_rec record track or loop or portion track that is in deck 1…i would record output about sampler…for example i would record sampler 1 playing + sampler 2 playing + sampler 7 playing, like a rekordbox sequencer…now i make this recordind master output…but i would record only sampler output…
so output to a deck not in use. If all 4 decks are in use there is the invisible deck option but it might confuse your workflow.
sorry deck1 sample_rec is perfect! recording all sound that flow in mixer channel 1 👏👏
question: can i record from sampler headphones? wich is correct script? sampler_rec ‘headphones’ or ‘headphones’ sampler_rec don’t works :(
answer; no not possible.
get_beat_bar & some applied maths.
May as well write something, and I last said, get_beat_bar, so what is it?
It returns a value between 0.0 & 1.0 to represent the current position of the current bar,
if it returns 0.25, you're exactly on the second beat, 0.5 third beat.
it accepts a parameter [any positive integer]
so get_beat_bar 1, returns 0.5 when you are half way between two beats
get_beat_bar 32, returns 0.5 when you are exactly on the 17th beat.
lets make something with it. How about an echo that turns itself off
effect_active 'echo' on & repeat_start 'rsEchoEnd' 30ms -1 & param_bigger `get_beat_bar 4` 0.03125 ? effect_active 'echo' off & repeat_stop 'rsEchoEnd' : nothing
nothing much to it, echo on, rsi started, when 0.03125 is bigger than what beat_bar 4 returns, turn the fx off and the rsi off
let's do something a bit more involved.
let's make the filter dial oscillate from off [50%] to 80% and back over 8 beats. button on button off
Without thinking we'll do the bits we can do without thinking, button on button off logic, is a rsi running? yes stop it : no so we'll start it
repeat_start_instant 'filtOsc' ? repeat_stop 'filtOsc' : repeat_start_instant 'filtOsc' 30ms -1 &...
we have some things to figure out. Lets think about going up from 0.5 to 0.8 first.
when beat_bar 8 returns 0.0 we want the filter to be 0.5
when beat_bar 8 returns 0.5 we want the filter to be 0.8
so 0.5 change from beat_bar is 0.3 change in the filter, so 3/5ths, multiply by 0.6, then add 0.5 because our filters start is 0.5
get_beat_bar 8 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
test that on a button, it seems to work, but it breaks our design spec when beat_bar returns more than 0.5, let's check for beat_bar >0.5
param_bigger `get_beat_bar 8` 0.5 ? 0.5 is bigger than beat_bar, we have the script for that : 0.5 is smaller than beat_bar, we need to work out how to do that.
0.0 to 0.5 worked very well for the way up, how can we get 0.5 to 0.0 for the way down?
well, 1 - get_beat_bar 8 would do that but how to script that.
get_beat_bar 8 & param_multiply -1 & param_add 1 &
*SIDE NOTE AT THE END*
try it out on a test button
get_beat_bar 8 & param_multiply -1 & param_add 1 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
seems ok when beat bar is > 0.5, lets combine both buttons and the >/< 0.5 check
param_bigger `get_beat_bar 8` 0.5 ? get_beat_bar 8 & param_multiply 0.6 & param_add 0.5 & param_cast & filter : get_beat_bar 8 & param_multiply -1 & param_add 1 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
Strap it all together, job done
repeat_start_instant 'filtOsc' ? repeat_stop 'filtOsc' : repeat_start_instant 'filtOsc' 30ms -1 & param_bigger `get_beat_bar 8` 0.5 ? get_beat_bar 8 & param_multiply 0.6 & param_add 0.5 & param_cast & filter : get_beat_bar 8 & param_multiply -1 & param_add 1 & param_multiply 0.6 & param_add 0.5 & param_cast & filter
Side note
works but could also be expressed as
get_beat_bar 8 & param_invert &
wow!!
hi at all! i’m modifying sampler page and i would record with pad 9-16 in rightdeck what i “play” samples 1-8 in leftedeck..like a sequencer. i’m in “Recordings bank” and i have put 8 samples..in this way i can play samples in leftdeck….in rightdeck with pad 9-16 i would record what i play (for this i have a var ‘bank’ = 0 for pad 1-8 and 1 for pad 9-16) and i have mapped pad 1:
var ‘bank’ 1 ? leftdeck ? sampler_bank ‘recordings bank’ ? sampler_loaded 9 ? sampler_pad 9 : sampler_rec 9 ‘master’ : sampler_pad 9 ‘master’ : sampler_bank ‘recordings bank’ ? sampler_loaded 9 ? sampler_pad 9 : sampler_rec 9 ‘master’ : sampler_loaded 9 : var ‘bank’ 0 ? leftdeck ? sampler_bank ‘recordings bank’ ? sampler_loaded 1 ? sampler_pad 1 : sampler_rec 1 ‘master’ : sampler_pad 1 : sampler_bank ‘recordings bank’ ? sampler_loaded 1 ? sampler_pad 1 : sampler_rec 1 ‘master’ : sampler_pad 1 : nothing
and i have mapped param1:
param_bigger 0.5 ? var ‘bank’ 0 ? sampler_loaded 8 ? set ‘bank’ 1 : nothing : var ‘bank’ 1 ? set ‘bank’ 0
but my problem is in rightdeck (with var ‘bank’ 1) sampler_pad 9 ‘play’ same sample in leftdeck sampler_pad 1 (with var ‘bank’ 0) :(
can you help me?
thanks!
hi, is there a script to zoom scratch zone (in Pro Skin)…i have tried zoom_scratch but zoom only deck waveform..thanks a lot
zoom_vertical
locodog wrote :
zoom_vertical
yeah! thanks
I want to scratch -60000ms/BPM (scratch backwards by one beat).
Is there a way to write a VDJ script to achieve this?
I'm not sure how to combine the scratch and get_bpm command with param_multiply or param_1_x.
scratch_dna "-Q"
try that, not exactly sure what you're after.
hi! i have mapped an encoder that move a sample in sideview ‘sampler’ with var ‘samplermove’ 1:
encoder: browser_window ‘sampler’ ? var ‘samplermove’ 1 ? param_smaller 0 ? browser_move -1 : browser_move +1 : nothing : nothing
but, for example, if i move sample 1 to 3 position and i play with pad 3 i can’t listen new sample in position 3, but i listen old sample 3 :( is not a really moving with script ‘browser_move’?
thanks who help me
appears so.
list looks to visually change, order seem to match but this is only visual and temporary
nothing is done, even using the mouse
exiting the bank and enter the bank again restore initial order
easy to see using sampler pad, no name change
this only moves slot position on screen, but do not move sample from slot to another
nothing save
34%
