Perhaps you can experiment with save_deck_set and load_deck_set then.
Also, you could set a "temporary" hotcue (let's say hotcue 99) on the position that you want to keep in memory, that you can delete afterwards (after you resume your working with the mix the next day)
So, instead of trying to seek to position 48.87% on the song (that would be what song_pos reports) you have a hotcue ready to take you there. And hotcues are virtually unlimited in VitualDJ. Therefore you don't have to "waste" a "good" slot (hotcues 1-8). You can decide to always use hotcue 99, or hotcue 20 or whatever number you want..
PS:
I have done what you do once or twice, and my way of doing things was quite simpler:
I made it a habit to always end my "partial" mix on a song with 0% pitch adjustment and flat EQ that would play until the end.
Then on the next session I would start mixing from the beginning of that same song and I would not adjust pitch / EQ until it was time to mix the next one.
Therefore, in post I would have plenty of "space" where both parts of my long mix would play the exact same part of a song with the exact same "settings". So it would be easy to "overlap" and mix cut them.
PS:
geposted Tue 22 Jul 25 @ 7:27 am
Thanks for your opinion and very helpful information!
I was able to save the pitch value and the pause point with save_the_deck. I'm satisfied with just that, but it couldn't save the EQ value. It would be great if the EQ value could also be saved.
geposted Tue 22 Jul 25 @ 7:40 am
The xml file saved by save_deck_set looks like this:
<deckset version="850" date="2025/07/22">
<load deck="1" filepath="xxx.wav" volume="4096" pos="5985252" gain="2048" pitch="4377"/>
<load deck="2" filepath="yyy.mp3" volume="4096" pos="4616170" gain="2048" pitch="3824"/>
</deckset>
I wonder if it is possible to specify high, mid, and low attributes in the load tag by editting this xml file manually.
geposted Tue 22 Jul 25 @ 1:57 pm
Probably not, as part of your save deck set procedure you could write a script to an unused tag and recall it next time round.
geposted Tue 22 Jul 25 @ 2:34 pm
I tried various attribute names such as high, eq_high, eq_high_freq, but I couldn't specify equalizer values. It's strange that we can't specify equalizer values even though there is GAIN attribute.
geposted Tue 22 Jul 25 @ 11:48 pm
Not strange really, eq wasn't wrote in to the xml when it was designed, machines only do as they're been told, they can't interpret outside what they're been told.
Just write a couple of buttons, save & recall
geposted Wed 23 Jul 25 @ 6:06 am
locoDog wrote :
deck num, never deck letter
you also used ' ' to wrap the 2nd param, that would make it literal text, you want to wrap in ` ` .
set_var 'titleA' `deck 1 get_title`
On this topic, is it good practice to use deck left, deck right ?
geposted Mon 28 Jul 25 @ 11:57 am
deck 'side' will work, best practice depends on case.
geposted Mon 28 Jul 25 @ 12:05 pm
Hello!
I have a question about the display behavior of buttons or pads. (on/off)
I tried creating pads with these:
(browser_window 'remixes' && show_splitpanel 'sideview')
(browser_window 'automix' && show_splitpanel 'sideview')
If the remixes tab is active, then my remixes pad will be on, and the automix one will be off as expected.
Unfortunately, the action is not exactly what I wanted so I did this instead:
(browser_window 'remixes' && show_splitpanel 'sideview') ? show_splitpanel 'sideview' off : (show_splitpanel 'sideview' on & browser_window 'remixes' on)
(browser_window 'automix' && show_splitpanel 'sideview') ? show_splitpanel 'sideview' off : (show_splitpanel 'sideview' on & browser_window 'automix' on)
The action is now fine but the pad status is now reversed?? I don't undersant why and I'm running in circles trying to fix it.
Thanks in advance for your help!
geposted Mon 28 Jul 25 @ 12:06 pm
Thanks!
geposted Mon 28 Jul 25 @ 12:07 pm
(browser_window 'remixes' && show_splitpanel 'sideview') ? on & show_splitpanel 'sideview' off : off & (show_splitpanel 'sideview' on & browser_window 'remixes' on)
common mistake when first dealing with button led logic, the reply to the query to turn the thing off should first tell the led to be on [because it is on], LED queries happen constantly, unlike button press triggered queries that only happen when button pressed.
geposted Mon 28 Jul 25 @ 12:34 pm
@Yan Duval:
A lot of times it's easier (and preferable) to "unlink" the led query (when the led is on) from the action of the pad.
Take a look at these examples:
<pad1 name="`get_effect_name 1`" color="effect_active 1 on ? var_equal 'FX1MomPush' 0 ? color 'green' : color 'blue' : color 'blue'" query="var_equal 'FX1MomPush' 0 ? effect_active 1" autodim="false">effect_active 1</pad1>
<pad5 name="^ MP" color="effect_active 1 on ? var_equal 'FX1MomPush' 1 ? color 'green' : color 'blue' : color 'blue'" query="var_equal 'FX1MomPush' 1 ? effect_active 1" autodim="false">effect_active 1 on while_pressed & set 'FX1MomPush' 1 while_pressed</pad5>
geposted Mon 28 Jul 25 @ 1:04 pm
Thank you both for your help.
I'll try these and come back to you!
geposted Mon 28 Jul 25 @ 4:15 pm
This works fine, thanks again. It brings more questions:
1- When part of a "query=...", are the actions actually performed or are they simply muted and used only as queries?
2- "A ? B" used above is the same as "A or B" if "or" was available in VDJ script?
3- Can "A ? B" used in any context without the ":" or does it sometimes need to be: "A ? B : nothing"
4- If an action is quite complex, can it be useful for performance reasons to modify a variable in the action in order to have a very simple query? I assume that if a query is available, the action stops being queried and is only performed when the button is presse?
With extras:
5- I sometimes see $myvar used without the ''. Like "set_var $myvar" instead of "set_var '$myvar'" Does it have a special meaning, or is it only that it's tolerated by VDJ in certain situations?
6- When used with a varialbe, is there any difference between "set" and "set_var".
Thanks!!
With extras:
Thanks!!
geposted 20 hours ago
5 tolerated, I have a topic quite recently on when " ' or ` can be omitted. Not sure if I added it to the first page index.
[I haven't yet it's a few pages back Posted Sun 20 Apr 25 @ 11:00 pm
6 Generally no difference for values, although set_var makes strings easier, example
set a 1 & set b a, both a & b will be set to 1, because that's how the set verb has worked forever, b is set to the same value as a.
set a 1 & set_var b a, a will be 1 as you'd expect but b will be set to the literal text "a"
1 LED/skin queries perform no actions they don't set variables they don't cause actions like "play" to happen, they just query
Other questions I'm not following your meaning.
geposted 17 hours ago
Thanks for answers 1, 5 and 6.
For questions 2 and 3, I was refering to the following
I am perplexed by the fact that there is no ":" That is "A ? B" instead of "A ? B : nothing"
Question 3 can also be reformulated as: Is "A ? B" valid not only in "query" but also in "action"? Does it mean the same as "A ? B : nothing" , or "A ? B : false" ?
Question 2 answer was no, I made an error. But I guess " A or B" can be written as "A ? true : B" in vdj script. Is that right?
Question 4 was not too important.
Thanks again!
Thanks again!
geposted 13 hours ago
