Topic: Script School - Page: 53.7
The xml file saved by save_deck_set looks like this:
<deckset version="850" date="2025/07/22">
<load deck="1" filepath="xxx.wav" volume="4096" pos="5985252" gain="2048" pitch="4377"/>
<load deck="2" filepath="yyy.mp3" volume="4096" pos="4616170" gain="2048" pitch="3824"/>
</deckset>
I wonder if it is possible to specify high, mid, and low attributes in the load tag by editting this xml file manually.
Probably not, as part of your save deck set procedure you could write a script to an unused tag and recall it next time round.
I tried various attribute names such as high, eq_high, eq_high_freq, but I couldn't specify equalizer values. It's strange that we can't specify equalizer values even though there is GAIN attribute.
Not strange really, eq wasn't wrote in to the xml when it was designed, machines only do as they're been told, they can't interpret outside what they're been told.
Just write a couple of buttons, save & recall
locoDog wrote :
set_var 'titleA' `deck 1 get_title`
deck num, never deck letter
you also used ' ' to wrap the 2nd param, that would make it literal text, you want to wrap in ` ` .
On this topic, is it good practice to use deck left, deck right ?
deck 'side' will work, best practice depends on case.
Hello!
I have a question about the display behavior of buttons or pads. (on/off)
I tried creating pads with these:
(browser_window 'remixes' && show_splitpanel 'sideview')
(browser_window 'automix' && show_splitpanel 'sideview')
If the remixes tab is active, then my remixes pad will be on, and the automix one will be off as expected.
Unfortunately, the action is not exactly what I wanted so I did this instead:
(browser_window 'remixes' && show_splitpanel 'sideview') ? show_splitpanel 'sideview' off : (show_splitpanel 'sideview' on & browser_window 'remixes' on)
(browser_window 'automix' && show_splitpanel 'sideview') ? show_splitpanel 'sideview' off : (show_splitpanel 'sideview' on & browser_window 'automix' on)
The action is now fine but the pad status is now reversed?? I don't undersant why and I'm running in circles trying to fix it.
Thanks in advance for your help!
Thanks!
(browser_window 'remixes' && show_splitpanel 'sideview') ? on & show_splitpanel 'sideview' off :  off & (show_splitpanel 'sideview' on & browser_window 'remixes' on)
common mistake when first dealing with button led logic, the reply to the query to turn the thing off should first tell the led to be on [because it is on], LED queries happen constantly, unlike button press triggered queries that only happen when button pressed.
@Yan Duval:
A lot of times it's easier (and preferable) to "unlink" the led query (when the led is on) from the action of the pad.
Take a look at these examples:
<pad1 name="`get_effect_name 1`" color="effect_active 1 on ? var_equal &apos;FX1MomPush&apos; 0 ? color &apos;green&apos; : color &apos;blue&apos; : color &apos;blue&apos;" query="var_equal &apos;FX1MomPush&apos; 0 ? effect_active 1" autodim="false">effect_active 1</pad1>
<pad5 name="^ MP" color="effect_active 1 on ? var_equal &apos;FX1MomPush&apos; 1 ? color &apos;green&apos; : color &apos;blue&apos; : color &apos;blue&apos;" query="var_equal &apos;FX1MomPush&apos; 1 ? effect_active 1" autodim="false">effect_active 1 on while_pressed &amp; set &apos;FX1MomPush&apos; 1 while_pressed</pad5>
Thank you both for your help.
I'll try these and come back to you!
