Topic: Script School - Page: 6.15
Adion wrote :
You could also just have a look at the keycue pad page if that's what you're after, and you'll see that it uses keycue_pad
I have already used it, but most likely I did not correctly spell out the name of each pad, and the numbers there are available from 1 to 8, so you need to first give names to each of the 25 pads, then use the same 25 names for Launchkey
locodog wrote :
don't just requote, tell me what's happening
this is working, yet
get_constant +1 & param_cast 'absolute' & key & cue
get_constant 3 & param_cast 'absolute' & key & get_cue & param_cast & hot_cue
get_constant -3 & param_cast 'absolute' & key & get_cue & param_cast & hot_cue
Thank U! All is working!
Now there is a second task. Let's try to expand the possibilities.
We leave it as it is, and add the PRESS function, i.e. when holding one key and pressing the other one sequentially, it does not return to the CUE point, but continues to play according to the key of the next key.
Will it work, do you think?
var '$isbgp' 0 ? get_constant -3 & param_cast 'absolute' & key & get_cue & param_cast & hot_cue & set '$isbgp' 1 while_pressed : get_constant -3 & param_cast 'absolute' & key
May as well copy this in, [nothing to do with yours Zvook]
new casting types
param_cast 'relative'
it fixes a bit of a script maths blindspot, limitations for casting that existed when actions could accept either a relative or an absolute value, like goto can.
before a positive number variable was always seen as an absolute, and a negative was always seen as relative and not much could be done without some serious script gymnastics. now you can tell the script, relative or absolute.
absolute has most uses when the number you are dealing with is negative
relative has most uses when the number you are dealing with is positive
get_constant 1 & param_cast 'absolute' & goto
this will go to beat 1 [the one after the zero/first beat]
get_constant 1 & param_cast 'relative' & goto
this will go just one beat forward where ever you are at the time
other useful things it opens up, incrementing things
set 'a' 0.1 & get_var 'a' & param_cast 'absolute' & level
will set the level at 0.1, [because a==0.1 is absolute already you don't need to really include it, same result as set 'a' 0.1 & get_var 'a' & param_cast & level]
set 'a' 0.1 & get_var 'a' & param_cast 'relative' & level
will increase the level by, 0.1
hello
I don't know how to start for this script : I want to map my 16pad controller (with rgb led) to sampler. I easily find the way to assign the color to sampler_pad.It works perfectly but now I want to say to VDJ "if this pad is playing change color of the pad AND also if it is trigger "hold" stay with this color and if trigger is "stutter" just make a momentary change of color...I don't know how to start with this....i started with a "while_pressed" on my button but it act like stutter and don't stay if it is hold :)
thanks in advance
fred
break it into a bunch of queries
sampler_play 1 ? sampler_mode 1 'hold' ? COLOUR FOR HOLD : sampler_mode 1 'stutter' ? COLOUR FOR STUTTER : QUERIES FOR OTHER MODES : NOT PLAYING COLOUR
thanks again locodog ;) i see clearer with this :)
Hello,
I hope I am in the right section to post this.
I am using the Virtual Dj 8 official PRO Layout (Skin) with the 3 different Effects on each deck.
I am also usind a DDj SX 3 Controller.
I managed to use the FX buttons on the top left (top right) of my controller to turn the Effects On and Off, also using the knob on the controller to use the effect slider for the Strength of the effect.
The DDj SX3 has then another Knob for Pushing and spinning (FX Beats / FX BeatsPush) which I am using now for the Effect Slider 1.2 (length).
My plan is, to use the FX Beats knob to toggle between Effect slider 1.2 , 2.2, 2.3 (while pushing it) and then be able to use the Effect slider for length by turning /spinning the knob.
I hope I made myself clear, English is not my first language.
I tried all day, but I gave up now. I just switched from Serato to Virtual DJ ( also tried Traktor but it didnt work well). So far, I really really like VDJ.
push
cycle 'beatPush' 3
dial
var 'beatPush' 0 ? effect_slider 1 2 : var 'beatPush' 1 ? effect_slider 2 2 : var 'beatPush' 2 ? effect_slider 3 2 : nothing
AMAZING!!!
That just did it!
Thanks so much.
PS: Do you know, if its possible, to make a Turntable visible as same as in the starter or Essentials layout? I Played around with it but it gave me only errors.
I am going to buy Pro soon I think ( I have to with ddj sx - No Home Plus) and then I will choose " The thing I guess....but till then would cool to see some spinning vinyls)
Currently thats only in Starter/Essential...
But will be some updates coming with extended options for those who want this and that ;-)
Thank you. Sounds good to me. Its actually useless, but I really like seeing it. :)
All.
THanks to Locodog for pointing me here. I've done a bunch of reading but I'm not understanding the syntax
I'm trying to do something simple- One button to do an Echo at a certain % strength and length
I thought effect_active "echo 60%" would do it as I've tried to copy something I saw but that didn't work. Again not understanding the logic here
Help Please
RT
effect and prameters can't be set the same time
echo : have 4 sliders : strench, length, lowpass, highpass
and 2 buttons : Mute source, trailing stop
set them individually :
strench:
effect_slider "echo" 1 60%
length : 3/4 beat
effect_slider "echo" 2 0.60
(its not user friendly, its effect internal) but it's a beat slider so
effect_beats "echo" 0.75
effect_beats "echo" 75%
will set 3/4 beat as well
hear source:
effect_button "echo" 1 off
... and activate effect
effect_active "echo" on
final command:
effect_slider "echo" 1 60% & effect_beats "echo" 0.75 & effect_button "echo" 1 off & effect_active "echo" on
Nicotux,
Thanks- will need to process this- quick quest which I still don't get- whats the "1" for- or the 2 as I've seen in other posts?
RT
these are the index of the "button" or the slider "slider" as they appear in the gui
without effect
effect_slider 1 0.60
with active effect and slider 1 0.60
effect_active 1 echo & effect_slider 1 0.60
full script
effect_active 1 echo & effect_slider 1 60% & effect_slider 2 0.75 & effect_slider 3 0.75 & effect_slider 4 0.75
effect_active 1 echo & effect_slider 1 60% & effect_slider 2 75% & effect_slider 3 75% & effect_slider 4 75%
11%
